WizComfort
Two issues
1. WizComfort hasnt been working for ages - until I noticed the \"bind to IP address\" - my IP will change because of dhcp. This now works. Comfigurator doesnt need this - why does wizcomfort ?
2. With my latest config, wizcomfort is now showing the CBUS tab - how can I enable this ?
1. If you are using DHCP, then do not fill in that field.
2. Does your CCL file have a UCM defined as a CBUS type? If you do and it does not work, try selecting the CCL file again.
Adrian
Yes, my UCM is defined as CBUS in the CCL and i\'ve got no issues with the Comfort <> CBUS talking
I\'ve also noticed WizComfort doesnt list any of the time programs either
Have you tried reselecting the ccl file under setup?
If it still doesn\'t work kindly send the ccl file to me to investigate.
Yes, I have multiple ccl\'s, as each new change i do creates a new ccl.
sent via email
Don\'t seem to be facing the same problem.
Could you send me the 2 ini files in the WizComfort directory?
Here\'s the screenshot.
done - here\'s my screenshot
I see on YOUR screenshot the outputs tab is greyed out - and do the time programs list on yours ? they dont on mine.
The outputs tab is greyed out as I did not enable the settings. No problems after doing so.
I noticed that you did not specify the ifr directory and iomap locations which I believe are the cause of your problem.
Odd, I\'ve never set those values before. I\'ve set them now, restarted wizcomfort, same problem.
And if i remove the bind to local ip address, the damn thing keeps coming back (192.168.0.1)
