Threads: 36
I replaced my wireless access point with a wireless adsl router.
In Comfigurator, when I sign in I get a message NO RESPONSE FROM UCM
In monitor Ucm shows :
Tx: <STX>LI1234<CR>
Any ideas
Threads: 36
Fixed, Changed the baud rate to 9600
Threads: 36
Each time I start my PC and try to connect to Comfort, I get the following message in Comfigurator :
Unknow exception while connecting to Ucm
To fix this I must either :
1. Reboot DS Manager OR
2. Press the reset button on the UCM
Any ideas on how to resolve this issue ?
Threads: 888
Next time can you run Hyperterminal instead and set up the comms as IP address and port, then try to login using LIcccc where cccc is your code. See what message you get if any
