Comfigurator 2.2.0 - Security Type Settings - Zone Type bug?
I have installed comfigurator 2.2.0 and am using it with Comfort Ultra II.
When I go into Security Type Settings / Zone Type and click on one of the Zone Types, the dialog box for that Zone Type opens up (new to 2.2.0).
However, while it gives the current settings for most of the parameters for that Zone Type, for both \"Night\" and \"Sensitivity\" it gives the settings as \"Perimeter\" and \"10\" respectively.  If you save then these \"wrong\" settings are also saved.
Has anyone else this problem?
I have a similar problem: The values I get in the grid for the Sec Off/Away/Night/Day are different from what I get in the popup window.
For example in  Zone Type 1 Door Window in the grid I get the correct settings:
Disabled/Immediate/Immediate/Immediate
In the popup I get:
Disabled/Disabled/Immediate/Immediate
Then when I click OK, the grid gets updated the wrong settings!!!
I have tried it on both Windows XP SP2 and VISTA Ultimate.
Thanks for the feedback. We can verify that this is a bug, and it will be corrected in a maintenance release. This has been added to the \"Known Issues\" list at http://www.comfortforums.com/view_topic.php?id=684&forum_id=20
This bug has been fixed in 2.2.1, see http://www.comfortforums.com/forum20/735.html
