Threads: 196
The software now defines these products which is great - however i believe that the hardware now needs to catch up? Will there be a dedicated Lutron Dynalite Rako UCM?
Threads: 15
the UCM/485, is used as the Dynalite UCM. It gives one way control on Dynalite, using Dynalite language terms from within Comfigurator.
If you want two way control of Dynalite, use the DNG232 from Dynalite and a Comfort UCX or UCM interface.
I would like to see a rako ucm as well.
Regards Ian
Threads: 880
Lutron and Rako can be supported (one-way) with regular UCMs using Action 197
The Response Wizard helps programming by translating the set of commands to the correct action 197 commands
