Comfort and heating integration
I read the above post about honeywell smartfit already, so really looking for a bit of advice. If i am integrating 12 zones of heating into a system that uses comfort and integrates with c-bus lighting control then:
1. am I better to let c-bus (12 channel relay) control the zones rather than the outputs on the comfort
2. (same for curtain/blind controllers)
3. Is smartfit the best panel to use? what cable and fitting is used at the heating panel
4. Do I have to use the smartfit in every room I want to control the heating or is it a thermostat
5. I am using touch panels in two of the rooms but in the other rooms how do I get away from having a clipsal light switch, a hideous plastic keypad, a smartfit panel etc all in a row? seeing as the point of the install is integration????
thanks
Jamie
