Threads: 885
No, those other reported issues are not related. What you have described is not a bug. It seems like a wiring or connection or configuration problem
Can you disconnect everything except the keypad. Load a default template and try the recording again? If it works then the problem is with the configuration or the way you have made the other connections
What firmware vertsion are you using?
Threads: 12
I have checked the wiring and saw nothing wrong. Also checked with your suggest configuration: only 1 KP with default simple .ccl file, and find that:
The beep - beep - continuously is no more on KP, but the phrase \'Thank you, good bye\' is heard right after the \"leave your...\" (or right after \"say your name\" in record user name, or in record greeting message for user...) so nothing can be recorded.
The firmware version that is ULTRA 5.045 as label on U1 of Comfort, or 5 45 24 1 in Engineer menu (7,4,3).
Threads: 885
Sorry, it was my mistake. 5.045 is an early version firmware which does have a bug in the recorded messages when the messages are full. Just delete all messages to allow recording again. We will send you replacement firmware
Threads: 12
Dear Mr. Chiu, it\'s OK, please send 02 pcs as I am having these two same Comfort panels here. Thanks
