Single chirp from bellbox every 10 seconds
A single chirp from the bellbox sounder every 10 seconds, this seems to occur after a battery test but continues long after the test is finished. There is a corresponding voltage drop pulse seen on the 12v supply, approximately 1v drop around 300mSec duration. I have isolated the supply to the PIRs and vibration sensors but the chirp remains. The voltage dip is still seen if the bellbox is disconnected.
That chirpo is due to the siren type pr sound type in Alarms. Look in alarm Types low battery - what siren tupe is assigned to it?
(07-18-2026, 05:31 AM)slychiu Wrote: That chirpo is due to the siren type pr sound type in Alarms. Look in alarm Types low battery - what siren tupe is assigned to it?
LowBattery is assigned Short Trouble and is assigned to keypads only, not bell output.
I have replaced the battery but the chirp remianed, however it has now stopped chirping after several hours.
If it happens again, send the cclx file to support@cytech.biz
