Threads: 206
I have a 'new' SEM01 from Laser - pretty sure its not ARM it only has "LEM" on pcb
Bar code label says P116908
OP03 - no label but two long chips on front
LEM with PCB writing PC01-059B and ink B0731 it has a bar code on front but no writing: on rear it has label C004467.
I have a PC01-056B OP01 plugged into the LEM
Can you please tell me if I have all the correct components to make up a slave panel with 8out 8in on SEM and 8out 8in on LEM.
And more importantly will these all wok seamlessly together using Comfig v3.14.14.0
Threads: 888
This is SEM01C - it is not the ARM processor, but funtionaly equivalent. The ARTM version of SEM was produced later than the Comfort Arm so this is the correct product
OP03B with 2 output drivers is the replacement for OP03
The LEM is LEM01-M2 - very old, about 15 years. It may bot work correctly when plugged into the SEM01C (which has no shunts)
I suggest buying a new LEM to work with the SEM
Comfiogurator 3 can be used
Threads: 888
So purchase an LEM01B
yes, dont use a 15 years part on a new installtion
Would you recommend that we update all firmware INC main CPU to latest version? (bear in mind we will be using Comfig 3 !
No need if you are not using any special functions and there is no bugs in the exiting firmware
I cannot see that Laser have an OP03 or an OP03B listed on their web site ?
They have OP01 but that is obsolete. Check wiuth aaron if they have OP03/OP03B both the part numbers will work
The main LEM board has ONLY one 4 pin interconnect bus/power cable connector the old pc had two - on in ad one out - how do you recommend that we take the bus connection through to the next device ?
The LEM does not have any 4 pin connection it is connected by ribbon cable to teh Main Board
Threads: 888
"" The main SEP board has ONLY one 4 pin interconnect bus/power cable connector the old pc had two - on in and one out - how do you recommend that we take the bus connection through to the next device ? ""
I m taking about the 4core mad up cables that you supply with all bus items !
The Old SEP only had one 4 way connector, not two. Only UCMs have two 4 way connectors
You can use the blue terminal blocks 12V, COM, KA, KB to make yopur connectisons to other ucms and other modules
Threads: 888
"So why have two separate connectors that do the same thing! Just do away withe the white 4 pinpcb connector ! "
do not use them if you have no use for them
