If/Then Programming example
This example shows how to do X from 6 AM to 11 PM and do Y at other times
If  Hours < 6 Then
   Do Y [Y]
Else
   If  Hours < 23 Then
         Do X [X]
   Else
       Do Y [Y]
   End If
End If
It needs to be programmed this way because Comfigurator is not able to do the following
IF (condition 1) AND (condition 2) THEN
or
IF (condition 1) OR (condition 2) THEN
So does it mean that a response such as follows will not work?
If Flag ILcozinhaFrt <> 0 Then
    If Input SC_LUZ_CZ_FRENTE = 0 Then
        Do ILcozinhaFrt_On []
        Do ILcozinhaFrt_Off [] After 300 Seconds Using IL_COZINHA_Frt
    Else
    End If
End If
Tks, Bruno
It will work. Any valid programming statement done with Response wizard will work
My point is that the OR statement is not possible current;y, if so it would make things simpler
I am wondering if anyond can help me with an if/then query?
I would like to turn on lights in hallway house once my comfort is disarmed. However I would only like it to do this at night, or more precisely I would like it to do this 60 minutes before sunset until 60 minutes after sunrise. I am a newbie and am getting the hang of programming, I have set the sunrise and sunset for my location using Comfigurator, I have found the night time parameter, but am not sure how to go the next step - is there a way?
Many thanks for any help.
My 2c worth, is create a number of different responses, rather than try and do it all in one response:-
First, create flags:-
1) Hall Light Flag
2) Sunset Flag
And timer, Hall Light Timer (if you want the light to turn off after a period)
Second, create responses:-
1) Hall Light on response does the following:-
If hall light flag is off
Turn Hall light flag on
Set hall light flag to on
Starts timer (hall light timer if you want to turn the light off after a while)
Else:
Start timer hall light
The above response is if you want the light to also turn off after a certain period. If the hall light is already on (flag is on), then all it does is reset the countdown timer, but if the flag is off, it turns on the light and starts the timer.
A second response is then needed to trun off the hall light as follows:-
2) Hall Light Off hall light off response
Turns hall ligh off
Sets hall light flag to off
3) For the timer you set up, have it run the Hall light off response when the timer expires
Now for the activation on security off if its nighttime
Create a response called \"Home time\" for example as follows:-
If flag sunset is on
Then:- Do response Hall light on
End
Last step then is to have the security off response point to your \"home time\" response.
The advantage of doing it this way, is that as you start wanting the house to do more on arriving home, al you need to do is create the responses, and then add them to the \"Home time\" response.
Hope this makes some level of sense, this is how I have my comfort system operating my x10 lights. If you want I can copy the repsonses from my fonfig file and paste them later when I get home!
Thank you for such a comprehensive response. Really very helpful. I am going to give that a go. Good suggestions, all my lights are X10.
If you could paste your code that would be marvellous.
I haven\'t made any flags as yet so this will be an interesting lesson. I am presuming that I can code the flag to be either side of the actual sunset sunrise - I am trying to overcome the issue of twilight.
Thank you
I would suggest starting off creating a flag and a timer for every element you have, so every x10 device etc should have a flag and a timer!
There is also an action Sunrise/Sunset Time Offset which can offset the sunrise or sunset time by a number of minutes
This wil change the time at which sunrise or sunset Responses are activated so you can for  example cause lights to be turned on before sunset and to be turned of after sunrise
However the automatic Night Time flag which is turned on between sunrise and sunset time is unchanged. You can test the Night Time Flag in an If condition without having to set or clear a flag manually
Is the sunrise / sunset offset set within the individual response, or is it a global setting? I don\'t suppose you can refer me to any example code featuring this offset could you? I am still picking this up.
Wexfordman - I have made all my timers and flags and am having fun!
The sunrise and sunset offset action causes the sunrise or sunset times to be offset by -128 to + 127 minutes from the programmed value. This allows you to, for example, turn on lights 30 minutes before sunset and/or 10 minutes after sunrise
In the above example the sunrise time has been offset by + 30 minutes, which means the Sunrise Response will be activated at Sunrise + 30 minutes
Offset Sunset time is done the same way
You create a Response with the action to offset the sunrise and/or sunset times. Then you need to activate the Response using an event for example in Time programs. This action remains in place until changed again by another sunrise/sunset offset action or until Comfort is reset
Note that this does not change the Night Time Flag which is automatically set between sunrise and sunset. It only changes the activation time of Sunrise or Sunset Responses
