Threads: 20
I have a CM9000-ULT in the original EN-03 enclosure with an ETH03 on a UCM
I am considering upgrading to the newer CM9001-ULT/A (that's if Laser in the UK can confirm they have the /A variant - as they don't show it as such.
Will a new CM9001-ULT/A fit into the EN03 or is any form of adapter plate needed? I assume I can move the ETH03 from the UCM to be directly connected tot he controller
I also will need to remove the AC transformer and replace with the switched mode PSU.
Threads: 885
Laser will only have CM9001A, the CM9001 has been out of production for at least 1 year
You can mount ther new board directly on the old metal box, the ,ounting positons are the same - no adaptor plate needed.
The ETH03 can be plugged into the CM9001
Threads: 20
Thank you for that, so likely they only have CM9001/A now.
Can I assume that I can just load an existing .cclx file from a Comfort II onto the CM9001/A variant?
Threads: 20
05-26-2026, 11:16 PM
(This post was last modified: 05-26-2026, 11:19 PM by cc_uk.)
Thank you for this, really helpful.
Last question I hope. Does a CM9001/A come with a OP03 board as standard or must that be ordered separately if outputs are needed?
I know my original CM9000 board came with an OP01 already fitted.
Threads: 885
Yes it includes an OP03B output board. the SEM01A does not include OP03B as most users dont need more than 8, but you canmorder OP03B for SEM01A for Slaves
Threads: 20
I now have a CM9001/A from Laser in the UK.
One observation I have relates to the power connector and the tamper connector. Both of these require the cables to be fitted into the two green plastic plugs which then fit into the sockets on the top edge of the board.
When the board is fitted into an original EN03 enclosure the top of these plugs almost touch the top of the enclosure and squash the cables, so not great spacing.
Secondly the MeanWell Power supply that will replace the AC transformer comes with short red & black cables that require extension to reach the CM9001 at the top of the enclosure.
Threads: 885
Thanks for the feedback, we will take note and review. By the way you can also get the EN01 enclosure which is more compact but better fitting. It can fir the main CM9001, 2 UCMs or LEMs, and a battery, and has a hinge for easier opening. the lighter weight means it is cheaper not only for manufacturing but for transport (as freight costs have risen lately). I think 2 EN01 may be the same cost overall as 1 EN03
Threads: 20
06-14-2026, 04:37 PM
(This post was last modified: 06-14-2026, 07:28 PM by cc_uk.)
This weekend I swapped the CM9000 for the CM9001/A
Everything has gone well, but a few observations and questions
The CM9001/A is running Firmware 8.034. It's inbuilt UCM running 8.023
The system has the ETH03 module directly installed on the CM9001/A board.
There is a LEM connected via the ribbon cable, and a SEM running 7.207
I have two keypads - both KP01A running 7.016
Finally an 8 button SCS version 2.004
My first question - does the in-built UCM get updated with the main controller firmware or separately?
My main issue is around the 8 button SCS. Initially is scanned OK but then I started to see communications failure and it would appear with random IDs when scanning.
Jumpers ABCD all had a link set on them which should indicate Id 1.
I removed all jumpers cleaned the contacts, which looks good anyway, and got the same result. I used a meter to confirm that continuity was set on all 4 jumper pairs - and again all checks out OK.
By deleting the SCS and then re-scanning it has appeared again with Id 1. However when I press any of the buttons on the SCS - Comfort does not respond with the response I have set for them, and the LED just flashes continually after that. in SCS/RIO responses I have set it to monitor, and all of the ModuleStatus for 129-136 always stays set to Off
I am also using the SCS temperature monitor the value from this does appear to be being read into Sensor08
Any ideas? I know the SCS is old, but hoping it is still compatible with the ARM edition of the controller, especially as there is nothing to replace it.
Lastly since I have the latest controller now - should it return it's serial number when scanned? As mine doesn't.
Threads: 885
T he CM9001 Firmware includes the inbuilt UCM functionality, so any upgrade will also include the UCM
The SCS shopuld still work with CM9001. We do not have any SCS in the office to test it with., we will have to look around for an old one. do you have 1 SCS?
the serial numbers may nopt be written into the device, but the bar code should show the serial number which starts with C
