Threads: 18
My system just reset itself and said something about \"key\" when it did so. I have no idea why this happened and need to look at as a next issue but currently the keypad shows each zones as it becomes active. Initially (after reset) it was calling out each zone (like walk test) but I seem to have resolved that. Now pad just showing each zone as they activate. Any advice on how to turn this off?
Threads: 880
05-27-2025, 01:03 AM
(This post was last modified: 05-28-2025, 08:00 AM by slychiu.)
Something may have changed in the programming or the eeprom. I suggest to open a default template and write to comfort. Then see if the problem still occurs. If so it ay be a hardware issue. If not then open your original cclx file and write to comfort again, and see if the problem has come back
