This affects new installations of Comfigurator on new PCs with new versions of Windows
Comfigurator installation requires .NET 3.5 to be installed, and will prompt for download and installation if it is not found on the PC.
When you try to install the downloaded .NET3.5 you may get a message \"a later version of .NET is already installed\" and this prevents you from going ahead with Comfigurator installation. If this happens go to Control Panel > programs and features.
Check the box for .NET Framework 3.5 shown below.
.NET 4.8 does not include .NET 3.5
The next version of Comfigurator will fix this problem or give instructions
