MultiSensor Module MSM01 Temperature and Humidity Graphical display
The Multisensor Module MSM01 has internal sensors for Temperature & Humidity as well as connections to water leakage detection cable for Water Leakage. It also has 4 external inputs for Dry contacts.
see http://www.comfortforums.com/forum139/4919.html for more info.
The temperature and Humidity can be mapped to Comfort Sensors eg
Setpoints for temperature and humidity can be set up, so that if the temperature or humidity exceeds the setpoints, an alarm can be triggered.
Comfort has an integration to the Home Assistant Platform see http://www.comfortforums.com/forum143/5577.html Home Assistant can be installed in a Respberry Pi. The Home Assistant User Interface can be accessed by Browser on any computer (PC, MAC, Linux) or on Mobile phone apps for iOS and Android. Notifications can be set up for registered Mobile phones when any temperature or humidity alarm occurs.
The current sensor value for Temperature and Humidity can be displayed on the Dashboard
Home Assistant also allows powerful graphing capabilities for the sensor values. The duration over which the sensor values can be selected eg 1 week, 1 month, and the time scale of the graphical display be  adjusted as well as the vertical Axis scaling and units.
Similarly Water Leakage sensor values can be displayed if required.
The Sensor Data displayed on the graph can be exported to a csv file
For details on configuration and setup in Home Assistant please see http://www.comfortforums.com/forum143/5624.html
Comfort EMS with MSM01 can be packaged and configured with Raspbery Pi and Home Assistant if required
