UCMA 8.007
Bugs
Bugs
- If ERR red LED remains on after reset or power on, it means the wifi submodule has been detected. If this occurs when USB or eth03 submodule is inserted in CM9001 or UCM, the ucm will not communicate. If tis happens power off and ON the UCN by removing and inserting the 4 way cable to the UCM. Similarly if wifi is inserted in the UCM baseboard the ERR red LED should be on. If it i not, then power off an on the UCM in the same way
- D?0000 queries ARM CM9001 and Slaves for battery voltages and DC voltages. allows Comfigurator 3.14.14 to read Battery ad DC Voltage values for CM9001 Arm processor
- TE command to test EEPROM size TExx where xx = 1 for 1st eeprom, 2 for 2nd eeprom in the UCM. If xx is missing defaults to 1st eepromno xx is 1st eepro. Repies with 08 = 24C256 256KBits size
