The ARM CORTEX M3 versions of CM9001, Slave. and UCM will replace the Toshiba 16-bit processor versions of the same products. Initially the functions of the ARM versions will be the same as the older version in order to ensure that the effort in migration are fully tested to be compatible. In future it will be easier to add functions or introduce new products with the new platform.
The CPU (Left) part of the CM9001 will be replaced by the Arm CPU board while the right DSP Board will remain the same. Hence both versions of the CPU board are compatible with the current DSP Board.
LEDS
The LEDS used in the ARM CPU board are high efficiency Surface mount types and are not easily seen when they are off. Their locations are indicated in the above photo with green or red highlights
ID0 to ID3 indicate ID for Slaves( SEM)
CM9001 and Slave Models and File Systems
The new CM9001 models wil be denoted by a suffix A, eg CM9001-ULT/A, CM9001-OPT/A. CM9001-EMS/A, CM9001-EX/A, LGXA01. They will use the same file system as the old models so the cclx file and program should be unaffected if the hardware is upgraded to the new version
The Slave model is SEM01/A with power sipply Board, SEM02/A without Power supply Board.
UCMA/Logic is the ARM version of UCM/Logic
UCM Models
The UCM Models are also appended with an A suffix after UCM eg UCMA/KNX, UCMA/Modbus, UCMA/4G, UCMA/Modbus, UCMA/Cbus.
Comfigurator
The minimum version of Comfigurator is 3.14.10 to support the new models.
After Scanning for Modules, the Controller Properties will show the Processor Field as ARM.
Download document from https://www.cytech.biz/download_files.php?item_id=1460
LEDS
- RX Green â Blinking Indicates RS485 Receive/ Reply from RS485 IDs
- TX Red â Blinking Indicates RS485 Transmit. CM9001 polling of RS485 IDs
- OFF (ID3) Green â Solid ON means Security Off. Blinking means Trouble (Zone Trouble, RS485 Communications Failure, AC Fail, Battery Low)
- ALM (ID2) Red â Solid ON means System Armed, Blinking means Alert or alarm state
- ERR (ID1) Red â Not used at Present
- ID0 Red â For ID only
- RESET (Highlighted in Yellow) - Reset Button. Press to reset CM9001 without changing the configuration or programming
- ID (Highlighted in Yellow)- Change ID for Slave. Press and Hold until ID0 to ID3 LEDS indicate the ID of the Slave, Press to increment ID. Has no effect for CM9001.
UCM Models
Comfigurator
