Threads: 205
The \'new\' LEM for the new CPU
Makes it VERY difficult to perform a manual system reset as the reset button is under the pcb !Also the pcb is VERY close to the 12v Ka Kb zone terminals making it VERY difficult to remove then
Threads: 205
Presume this is a design fault and nothing can be done about it now !
Threads: 885
08-10-2024, 01:34 AM
(This post was last modified: 08-10-2024, 03:07 AM by slychiu.)
On the Comfort CPU board you can plug in Output module (OP03), ETH03, LEM02B at the same time.
The Reset switch is positioned between these plug in modules so you can press it. although with a bit of difficulty if you have large fingers.
I would not call it a design flaw - it is a space limitation in order to keep the existing PCB size and Hole locations. There are hundreds of components on the Comfort PCBs
