Threads: 5
HiI am hearing a beep every minute that I think is coming from Comfort. it may be related to some zones acting as fire and CO alarms but I am seeing no messages trigged in the keypad. I can\'t tell as all the devices are physically close together! I see no error lights on any of the devices and have removed the CO and smoke detectors leaving some relays and am still getting a beep and have replaced the batteries on the smoke detectors.
Any ideas?Thank you
Mark
Threads: 885
Did you keep older versions of your cclx file? if so you can use them to see when this strange beep started
Threads: 5
hi - I don\'t believe it is CCLX change related. But if you don\'t recognise the beep pattern I am increasingly of the view it is not coming from the Comfort but from the fire systems (all the buzzers are co-located and the Aico fire alarms have a pattern that is light then buzzer) so it is proving hard to prove out!
Threads: 885
i dontthink comfort beeps 1 time every minute
Threads: 5
Solved it - was another device!
