11-13-2023, 11:55 PM
Hey guys,
I\'m trying to backwards engineer some programming that was left on the logic engineLGX01 by another commissioning ex-employee who has since left.
So far I\'ve been able to connect to the device via the ethernet eth03 connector but as soon as I try to read the logic module I get the following attached error.
Ive also tried to scan for all modules in the configurator application however à also recieve the exact same comfigurator error.
Do I need to upgrade the firmware or software or something?
I believe this install was done 5 years ago and I am using comfigurator version 3.14.3.0.
If anyone can point me in the right direction that would be much appreciated.
Thanks in advance.
Thanks in advance.
