Threads: 12
As being away and without a window based laptop (only macbook is a available), and there is a zone been being trouble. Its on/off or fault/ restore states causing Comfort sending out too many sms alerts - âZone xxxx troubledâ. How we can disable this trouble zone remotely in this situation only via sms or mobile phone calls?
Thank you.
Threads: 868
1
Call by phone to Comfort, when answer, sign in with user code, Press 3,5 for Bypass Zone. Enter zine no and # key. Press 1 for Bypass to bypass the zone
Threads: 12
Thanks Mr.Chiu.
I can bypass the trouble zone now via phone.
But I can not stop Comfort to continue sending out alert sms âZone troubleâ!
What should I do: change Comfort into test mode temporally ?
Threads: 868
1
If the zone is bypassed it cannot send out SMS for zone trouble bcause a bypassed zone means it is inacyive. Please chjeck which zone sends the sms and make sure that zone is also bypassed
Threads: 12
I assumed: the sms still be sent out for a while (02 hours!) after the trouble zone was bypassed - it could be from \"the mobile service company\'s buffered memory of previously sms\".
Anyway, it is ok now. Thank you.
