Threads: 880
10-22-2023, 05:19 AM
(This post was last modified: 01-29-2025, 01:23 AM by slychiu.)
Comfigurator 3.14.1 Changes from 3.13.9
Known Bugs
- Upgrade firmware for Controller shows \"Cannot Obtain Firmware Information\". Workaround - Please download firmware directly from https://www.cytech.biz/firmware.html Or downgrade to 3.13.9 at https://www.cytech.biz/download_files.php?item_id=1301
- Upgrading KP04, KP06, IRIO, MSM, TSM by Coimfigurator will case an error \"Incompatible File System\" to be displayed. Revert to 3.13.9 as workaround
- The number of IRIO Modules are not correctly detected after scan for modules for CM9001-EMS and CM9001-EMS2
- For UCM/KNX and KNX/Logic in KNX Monitor Mode, when logged in by eth03 in CM9001 telegrams do not appear in KNX Monitor or Learn Mode
Bugs Fixed
- For CM9001-EMS, No of slaves was limited to 3, now it can be increased to 5
- For CM9001-EX, No of slaves was limited to 3. Now it can be increased to 5
- The action Set Virtual Input On/Off could not select Virtual Inputs correctly
- When UCM ID1 is not connected, and Comfigurator is connected to UCM > ID2, Scan for Modules may show an extra UCM ID1 with firmware version 255.255
New Features and Improvements
- For the Register Monitor in Comfort Register, the right Pane Set Value box does not show the value of the register, so that if the value is constantly being updated, entering a new value will not be affected by the read values. The centre pane will show the register values that are updated constantly
- Supports Future UCM ARM processor models
Threads: 880
11-02-2023, 06:01 AM
(This post was last modified: 01-29-2025, 01:22 AM by slychiu.)
Comfigurator 3.14.4
- Fixed bug from 3.14.3- Upgrade firmware for Controller shows \"Cannot Obtain Firmware Information\"
Known Bugs
- If a new Comfigurator file (template) is started with a Comfort with IRIO, logging in will produce an exception. If a saved file with IRIO already present, this will not happen. As a workaround, add the IRIO manually and do a module scan again
- IRIO Properties for ISM01 Temperature sensor > Calibration offset - value -1 is always written - This is an old bug
Threads: 880
11-24-2023, 05:30 AM
Comfigurator 3.14.6
Known Bugs
Bugs Fixed
- Fixed Bug Upgrade PIC based products shows \"Invalid File format\"
- Fixed Bug IRIO > ISM Submodule > Temp sensor> Calibartion offset always writes FF
Threads: 880
01-12-2024, 02:57 AM
(This post was last modified: 01-29-2025, 01:21 AM by slychiu.)
Comfigurator 3.14.8
Bugs Fixed
- The number of IRIO Modules were not correctly detected after scan for modules for CM9001-EMS and CM9001-EMS
- For UCM/KNX and KNX/Logic in KNX Monitor Mode, when logged in by eth03 in CM9001 telegrams do not appear in KNX Monitor or Learn Mode2
- Sensors mapped to external modules are now unique ie you cannot map the same Comfort sensor register to different modules eg KNX, Modbus, IRIO. This is because Sensors represent temperature, humidity and other sensor values obtained from external sources. Allowing different modules to map to th same sensor would cause incorrecvt values to be assigned to the sensor. This feature ensures that different sensors must be assigned
[color=\"#ff0000\"]Note - after upgrading the software, it is best to do File > Update Defaults to update the default files form thee server. After that restart Comfigurator[/color]
Threads: 880
08-02-2024, 02:39 AM
(This post was last modified: 01-29-2025, 01:05 AM by slychiu.)
Comfigurator 3.14.10
Bugs
- When File system in converted to another, sunset responses always writes 0000
New Features
- Improved detection of Comfort Modules including ARM-based products
- Important - Please do [color=\"#ff0000\"]File > Update Defaults[/color] to update the default configuration files so RIO Modules outputs can be handled correctly in responses. This fixes the problem in Comfigurator that RIO responses give errors in red
- Misc Events > Sunset Responses - This parameter is not written to Comfort (written as Response 0)
Threads: 880
01-29-2025, 01:14 AM
(This post was last modified: 02-07-2025, 02:01 AM by slychiu.)
Comfigurator 3.14.12
Bugs
- The calculation of DC Voltage is wrong
- some newly created cclx files may cause exception when opened
Bugs Fixed
- For UCM/KNX and KNX/Logic in KNX Monitor Mode, when logged in by eth03 in CM9001 telegrams do not appear in KNX Monitor or Learn Mode.
- Defaults for Number of IRIOs have been updated
- One cclx file Flag 1 Graph References caused Exception
- Controller Properties will display Battery Voltage and DC Voltage Value for Arm Processor only (using the D? query). NOTE! there is a mistake in the calculation of DC Voltage
- IRIO Sensors - added parameter for interval between Updates to avoid flooding the RS485 Bus - which caused Comfort Register Monitor to not update correctly
- Supports new KNXA/Logic for Arm
- UCM/GSMA7608 Type is shown as A7608 instead of \"4\" in GSM Properties
- Scan for modules will return with Battery Voltage and DC Voltage values in Controller Properties
Threads: 880
Comfigurator 3.14.14
⢠fixed bugs some cclx files when opened have exception
⢠improved D? analog values for DC not correct
