Iâve recently had a situation where a particular zone went into trouble mode. So I disabled it via Comfigurator.
My Comfort installer took a look yesterday but we couldnât find any problems. He thinks itâs the LEM03 Local Expansion Module because the failing zone was on that board. The testing, refitting connectors, touching it, etc, seemed to âfixâ the problem, until a few hours later when three more zones (also on the LEM03) went into continuous trouble mode, despite Comfort being in Security Off mode as I was home.
At this point the internal and external sirens are going. If I typed in my code the sirens would stop only momentarily before picking up again. Scenes! Absolute chaos inside!! Itâs hard to think with Comfort screaming at me from every source - keypad, phone, sirens, etc.
I tried to enter the engineer menu so that I could got into security test mode, hoping that would calm all the sirens. But I simply could not manage it. Iâd enter my user code, then try to enter the engineer menu before the sirens kicked off again and Comfort keypad would just beep at me. I could not hear what it was saying over the noise of the sirens. It was hopeless, and I gave up trying to access the engineer menu at this point.
Eventually I got Comfigurator up - I had to sit through Windows updates, what a horrifically timed nightmare! - and was eventually able to DISable the zone inputs by changing the zone type to blank, then upload a new configuration. Weâre going to change the LEM03 board next.
But my question is: how should I have handled this zone trouble situation? What can I do immediately from the keypad to calm Comfort down? So that I know how to better cope next time around.
