Zone trouble after lightning strike.
Had a lightning strike in the last hour, which has resulted in all zones, reporting zone trouble. Despite the system is unarmed, opening of the back or front door results in an entry warning beeping from the keypads.I have reset the system through the keypad twice, but still all zones are reporting a fault.I have temporarily bypassed all zones and switch off the time programs, so the system doesn\'t try to arm itself, but coming up blank with what to do next. Any ideas?
Try reloading your cclx file but if it has been affected by lightning not sure if that would help.
The lightning ay have come through the zone sensoers and damaged the controller PCB, or other areas.
Or It may also have activated some resetable fuses which may recver after the short circuot is remived. Switch off all power and disconnect bater for 5 minutes then turn in again.
Read the event log to see what is recorded
