Threads: 17
1
01-24-2022, 12:25 PM
(This post was last modified: 01-24-2022, 12:26 PM by srooks.)
I\'ve just added a KP04 into my system, which is
Comfort II Ultra
7.142
FS 34
Vocab 5
Not customised
System Vocab 35
User Vocab 1
LCD Txt 2
Min KP 3
Keypad says wrong text , *1 to sync
When I press *1 , get the download aborted no text
Is the KP too old, or do I need to upgrade anything? Thanks.
Threads: 885
Does the KP04 announce the vioice menu when you enter your user code and # key?
This is to check if the Vocabulary is working. If there is no vocab then the text sync with KP04A will not work. If there is voice on the keypad, then do Sentence Tables Upgrade in Transfer Menu. Thi will write the sentences tables to Comfort which will allow it to sync with the KP04
Threads: 17
1
looks like I have a bigger issue. Not getting audio from KT03 or when I call in on fixed line and log in (after voice machine prompt)
Think it\'s a config issue or hardware? All that\'s happened was the KT03 was removed from the system. Leaving just the keypad.
Threads: 17
1
Thanks , I\'ve tried this a couple of times with myma43. I hear comfort beeping (like a reset) and then get an error from Comfigurator saying Vocab Errors.
I am using the Rpi as my UCM ETH.
Log is:
> LI****
< LU01
> DT
< DT2022013118025200
> EL
< EL1111FFFFFFFF
> UL000003
< DL000003FFFF22DD
> V?
< V?FE078E22400100
> v?
< v?FFFF0000000000000000000000000000
> U?
< U?4107741200
> f?00
> Y?
> Z?
> z?
> M?
> K?
> a?
> d?
< f?00FFFFC4C7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
< NA
< Y?00000000
< Z?000000
< z?000000000000000000000000000000
< M?00F1
< a?110000000000000000
> LT01
< OK
> VP0000C2C6
< OK
> VL00002055C2C45900BA02C403E20521061306E407D6092B0A330B3B0C850DB90F3A10D802
< NA
> LI
< LU00
Threads: 17
1
I have been able to do a sentence upgrade .. but vocab fails and seems to lock up comfort. It needs a reset to allow further downloads.
Still no vocab either via kt03 or dial-in
Threads: 17
1
No, I don\'t have a UCM available ..
Threads: 885
I suggest you buy a UCM, or if you have a CM9001, get a ETH03 submodule which can plug in to CM9001.
