Set time
I would like to set the time of comfort to be the same as my LAN. I know there is the opportunity when transferring to Comfort, but can I do it from a response?
You can synchronise the comfort time with Internet time if you have a UCM/ETH03 or ETH03 plugin (for CM9001). If you do not have it, It cannot be done with a Response because the response will not know what is the trime as the PC is not always connected
I do have ETH03 connected.
Then you can synchroise the time in CS Manager, there is no need for responses. see instructions in http://www.comfortforums.com/forum113/3695.html
Thank you for responding. I am aware that I can synchronise manually. I was hoping to automate the process, hence my request if it could be done via a response that I could activate at intervals via MQTT-python.
ETH03 sync with NTP Internet time is automatic, not manual, you set the interval eg 1 hour.
Thank you.
