I have a Comfort II with a Visconic MC308 connected to it.
I have two Visonic wireless PIRs - one is currently paired with the MC308. I am getting spurious false alarms on the Comfort system.
The PIR is fairly close to the MC308 so it\'s not a range issue. The PIR is in a closed box while I am testing, so not triggering it\'s sensor.
I have additionally removed the cover from the MC308 to put it into test mode. When the spurious alarms are received by Comfort they do not correspond with a PIR trigger to the MC308 (ie no success tone fropm the MC308).
I do hear the \'success tone\' from the MC308 every 10-12 minutes which I believe is a keepalive between the PIR and the MC308 These do not trigger a comfort alarm.
If I deliberately trigger the PIR I do get the success tone from the MC308 in test mode and Comfort does also trigger.
Therefore I believe the problem with spurious alarms lies between the MC308 and comfort
Comfort is configured with shunts not to require EOL resistors, and no EOL resistors are connected. There are three connections between comfort and the MC308 - 12V, 0V and Zone 1 on MC308 connected to Zone 4 input on the Comfort panel.
There is no connection to COM terminal on the comfort panel, for this zone, but I assume all the COM zone connections are tied to 0V anyway. And no connection to COM on the MC308
The Zone on Comfort is configured as a NC. I have tried with Digtial set to YES and to NO and Sensitivity values of 100, 200, 300, 400 & 500 and get the same result.
Shoudl this open collectior type connection be defined as Digital or not? What does that setting actually do on Comfort?
Any help appreciated.
