Threads: 4
Hello,
When trying to program my system, I get the following error: \"..the number od modules defined in Modules&Setting does not match the modules listed under the MOdules tab\".
My system did not change (add or remove modules).
I did a scan for all modules (pic attached).
What am I doing wrong ?
Thank you
cytech_errors.pdf (Size: 421.59 KB / Downloads: 4)
Threads: 885
If you get this message, you should do a scan for all modules in the Modules Tab. Then write Modules and settings to Comfort
You may have got this message because you manually added modiles By \"Add Module\" instead of doung a Module scan. Or tyou did not do a wrte Modules and Settings or Wrote To Comforr.
Also check your UCM and Comfort firmware are up to date
Threads: 4
Hello,
A while ago, I had to reinstall my PC, and installed a newer version of Conmfigurator.When opening my old file, I received this message.
I\'m afraid of installing the new programming (just did some changes to time programs).
Doing a scan I get only one UCM.
Is it safe ?
Thank tou
Threads: 885
Yes you must do a scan to detect the modules
Threads: 4
Hello,
after programming, my UCM is no longer responding ...Tried a System Information, got \"No response from UCM\".Android and IOS not working.Can ping IP of UCM 192.168.1.9 ok.
Please help...!
cytech_error2.pdf (Size: 458.86 KB / Downloads: 3)
Threads: 885
Go to Comfort Server Manager in Options UCM connection and check that the IP address can be seen and is still correct
Wjat eth module do you have? ETH02 or ETH03?
Threads: 4
05-27-2021, 08:22 AM
(This post was last modified: 05-27-2021, 08:23 AM by rportela .)
Hello,
Configuration seems ok.I think its ETH2.
[img]data:image/png;base64,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[/img]
[img]data:image/png;base64,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[/img]
Threads: 885
UCM02 is the ID it does not tell yuou if it is ETH02 or ETH03You need to go to Comfort Server Manager for ETH03, od DS Manager for ETH92 and check if the IP address can be seen in either of themIf you cannot see the IP address then the EH02 or ETH03 may not be working
Threads: 4
05-27-2021, 08:45 AM
(This post was last modified: 05-27-2021, 09:11 AM by rportela .)
Hello,
Just installed Server Manager, but did not detect board.
I think I have older version.
Sending a photo. Does it help ?
Thumbnail(s)
