05-21-2021, 07:37 AM
Bugs Fixed
This firmware is in Beta test, but as it fixes some bugs some may want to test it.
Download from https://www.cytech.biz/product_details.php?item_id=210
- If firmware upgrade failed and Power off and on again, firmware uograde from UCM ID1 did not work
- Ultra could upgrade to EX by ETH03 plug in
- UCM/LOG and KNX/LOG did not work with RIO
- Eth03 plug in did not report RIO Input state change
- Vacation Mode for partition system did not set partition correctly
- If no zones are in partition 0, cannot arm partition 0 without zones. exit time does not end.
- When sign in by local r remote Phone, if user is enabled for more than 1 parttiions, announce \"select User\" to allow the user to select a higher partition. Normallyt users who are eabled for more than 1 partition are always logged in to the lowest partition.
- IDBUTTON pressed disable user response
- Arm security system if partition has no zones dont allow arm/disarm
- KP to DP Intercom. Keypad Press and hold button is one way KP to DP. If KP button is released then KP to DP is full duplex
- Added Test mode commands to support internal tester functions
