Threads: 865
Comfigurator has a bug for the num ber of slaves, as of 20 August 2023. It does not allowe the number of Slaves to exceed 3. This can be fixed by updaing the dxefault configuration files.
Go to Files > Update Defaults. The default updater software will run. aftyer completion, close and restart Comfigurator. Now you should be able to add up to 5 Slaves
Threads: 189
UPDATE DEFAULTS TAB
Can someone please explain how this is used (not how to use it!)
Apparently it is used by Cytech to fix firmware and bug issues prior to the release of new firmware.
We have use it when updating older systems as its easy to loose responses that are assigned through UCMS such as CBUS and KNX.
I suppose I\'m confused as to why updates are not issued more regularly to Comfigurator - why add further complication by adding another spurious undocumented process
Threads: 865
Update Defaults is used to update configuration files BEFORE the new version of Comfigurator is relaesed , NOT to fix Firmware bugs.
This
Threads: 189
\"Update Defaults is used to update configuration files\"
To be clear .....When I press update defaults your software is altering the .cclx file NOT the comfigurator software ?
Bearing on mind that we are fastidious in our maintenance of file versions... If we press the update defaults then we are in effect updating the .cclx file version ....and as such would need to update the saved file version even though we have made NO discernable changes? ALSO would we be required to upload to comfort for the changes to take place ?
So we could have a scenario whereby the update defaults has been pressed and the ile not saved as an updated version - Engineer or customer comes back to the set up using the same cclx file and the same problem re-occurs ?
Threads: 865
No, Update Defaults does not change any cclx file, or affect firmware, The deffault files may include the defalt templates, ie .cctx files, or the file specifying the maximum number of RIOs, IRIO UCMs in a comfort system. The recent file update was to do with the maximum RIOs in an Ultra file system
Threads: 189
So how come it \'fixed\' the problem of UCM programmed responses appearing in RED an not containing the code?
Threads: 865
The change was just in the configuration files, not cclx
Threads: 189
I think its my age .....
\"No, Update Defaults does not change any cclx file, or affect firmware, The default files may include the default templates, ie .cctx files, or the file specifying the maximum number of RIOs, IRIO UCMs in a comfort system. The recent file update was to do with the maximum RIOs in an Ultra file system\"
\"The change was just in the configuration files, not cclx\"
Configuration file ( or are thy called template files ?) - are you able to explain further please ...
Is there just one .cclx configuration file ( template file ) for each installation ?This is presumably stored in the main CPU ?What parameters does the file allow you change?Why can\'t you upload a configuration file offline?Is the .cclx file stored as part of a firmware upgrade?
I\'ve been uploading the configuration file today and it appeared to improve / alter some aspects of the programming / responses - is his correct ?
