03-02-2021, 10:26 PM
My ETH03 has 2 ports configured 1001 and 1002.
I usually use the first one for Comfigurator and I\'ve recently been testing a separate Comfort->MQTT Bridge connecting to the port too.
I had forgotten there was a second port and I\'ve now proved I can connect both at the same time - e.g. Comfigurator to 1001, and my MQTTBridge to 1002.
However, my bridge also seems to see messages to/from Comfigurator, so I assume the Comfort connection is more of a bus than an individual point-to-point connection?
So... can I assume it would NOT be safe to use Comfigurator to do any programming if my module was also connected and active? i.e. I should only have 1 device connected to Comfort via ETH03 when programming?
