Threads: 5
02-24-2021, 04:23 PM
(This post was last modified: 02-24-2021, 04:24 PM by 111rdw.)
I\'m trying to avoid running a wire to a door by using a Z-Wave door switch. I cannot understand after many readings of the manual and forum posts how (if it is even possible) how to do this. I can see the switch in the z-wave mapping but then it all gets a bit confusing to me - I\'m an amateur at this. If this is possible what do I need to do? thanks in advance
Threads: 885
First you have to Create a Virtual Node in UCM/Zwave so that the zwave door switch can send comands to it. There is a button to Create viertual Node. Then associate the virtual Node to the door switch which should be a ruting slave.
Next you can map the virtual Node to a Virtual INput in Comfort. A virtual Input is an unused input in Comfort which acts like a real input but is triggered by an external device like Zwave.
This allows zwave door switch to act like a real input. Thew releavent sections in the UCM/Zwave manual describe each of these steps
Threads: 5
Thanks. All sounds very simple now you have explained it. Iââ¬â¢ll give that a try.
Threads: 5
Taken me most of the day but it\'s working. My first mistake was trying to link the virtual and real nodes in comfort instead of my Fibaro HC2. And I could not get associations to work. However works fine using a scene to link them.
Threads: 7
I\'m really struggling with my Virtual inputs and responses. When I try to assign a virtual input on/off in Responses it wont let me select a different zone? It seems fixed on a single zone?
Threads: 885
For virtual zone onoff you should only be able to select zones that are Virtual, ie mapped to zwave as viertual zones. You are not able to select non-virtual zones
Threads: 7
thanks for the reply, I have the virtual input working perfectly on zone 17 but configurator won\'t let me create another virtual input with zone 18?
cheersmatt
