Front Porch Sensor Light On All The Time
I have set my front porch light to on when triggered by a Passive Motion Detector, between 7pm and 7am. It has been working all this while till today, it is always on though the PIR is not triggered.
Is there a way to reset this light? I have tried to shut down the mains for 5 minutes, didn\'t work.
Thanks, much appreciated.
I once had a similar issue and it turned out to be a spider nesting in the PIR!
Check that the Comfort time and date are correct.
Do a Security Check using Keypad F3,2 which announces all detectors when they turn on
Your PIR may be permanentyly on or Off.
If working, you should hear the PIR name when is detects motion
