Threads: 865
12-11-2020, 04:54 AM
(This post was last modified: 04-13-2025, 05:12 AM by slychiu.)
UCM 7.141
Bugs
- If ERR red LED remains on after reset or power on, it means the wifi submodule has been detected. If this occurs when USB or eth03 submodule is inserted in CM9001 or UCM, the ucm will not communicate. If tis happens power off and ON the UCN by removing and inserting the 4 way cable to the UCM. Similarly if wifi is inserted in the UCM baseboard the ERR red LED should be on. If it i not, then power off an on the UCM in the same way
Changes - Implemented wifi01 NTP update time at 00:10 hours or 10 minutes after each hour if not updated on the same day
- \"SB\" strobe proc232_strobe command
- Fixed BUG - report_counter counter value was corrupted so Comfort Increment Counter, Decreent Counterr actions did not return correct value in saveuservalue
- If UCM is doing firmware upgrade by UCM programming cable, suppress mesages Cs01 or Cs02 which may interfere with upgrading firmware
Threads: 865
01-16-2023, 12:12 PM
(This post was last modified: 04-13-2025, 05:13 AM by slychiu.)
UCM 7.150
Bugs
Changes
- Fixed bug from 18/11/20 Counter report gave wrong value CTNNvv
- Fixed bug if ucm/wifi does not log out, the timer for wifi reset does not work
- RS232 check for parity, framing and Overrun errors before reading data, so errors are not read into receive buffer
- Fixed Bugs in UCM DOWNLOAD and UPLOAD buttons
- RDY LED turns on at end of Upload/Download
Threads: 865
01-16-2023, 12:13 PM
[size=\"3\"] UCM 7.166 (17/8/22)[/size][size=\"3\"]
[/size] Bugs
Changes
[size=\"3\"] 1. Fixed wifi reset issues, wifi not work after some time
1. fixed bug from UCM 7.156 C!NNVV will reply ERNN
2. Fixed bug CTNNVV missing CT just NNVV is reported.[/size]
Threads: 865
01-16-2023, 12:17 PM
(This post was last modified: 04-13-2025, 05:14 AM by slychiu.)
UCM 7.167 (30/8/22)Bugs
- BUG from 26/12/20 did not check modbus master before call checking modbus to Comfort table. affect ucm/modchanged from master to slave - may send wrong info to master . may cause slave not to get correct info from CM9001
Changes
- Fixed BUG Reply to C?NN was wrongs
- d? query will reply d?00 if tmrmotion disabled (NOT NA)
Threads: 865
01-16-2023, 12:19 PM
UCM 7.176 (1/1/23)
Bugs
Changes
- Fixed BUG for SW7 ID setting did not work if all switches ABCD are off
- If wifi submodule is detected by UCM at reset, ERR LED will turn on and remain on. If others are detcted eg USB, ETH, ERR led will be off
- For newer USB submodules, connection to the PC supplies power to the USB. If at UCM/USB power on, the USB is not con nected to the PC, the wifi is detected wrongly, and the UCM/USB will not communicate. The ERR LED will then be ON. To fix this problem just press the RESET button on the UCM (after he USB is connected to the PC). For older USB hardware, pressing RESET will not do - a power cycle is needed. see http://www.comfortforums.com/view_topic.php?id=5413&forum_id=73 for more about this
- Upgrade SEM by ucm firmware upgrade cable updated for beter performance and reduce errors, fixed problems
- Implemented UUID for future feature
Threads: 865
02-16-2025, 03:04 AM
UCM 7.227
Bugs
Changes- Handled DT query while in Firmware upgrade
- added D?01 and D?21 query for DC voltage for arm CM9001 and slave
- Able to Handle upgrade of Arm and non-Arm CM9001, UCMs and Slaves
- UCMA7.227 for ARM and UCM 7/227 without A for non arm UCM firmware
