removed door station. advice please
I have recently removed the door station from my front door and reprogrammed the comfort to show 0 door stations.
Trouble is the telephones no longer work. the comfort doesn\'t dial out and I can\'t use an internal phone anymore.
Is there some else I need to do?
Sounds like the telephone wires have been pulled out of the comfort panel to me or one of the cables for telephone has been damaged, have you tried bypassing comfort?
Removing door station should not affect your telephone as Swiss says
thank you, I shall go and re check wiring and try bypassing the unit.
Is it a C1
If it is then its no longer supported AND dont use current software to configure. \ his may be the problem
