Wifi01 is a sub-module which plugs in to UCM06, CM9001, LGX01 or UCM/Logic which connects to a wifi Access Point for programming by Comfigurator or for use by the Cytech mobile apps.
Wifi Specifications
- Wifi Standards: 802.11 b/g/n
- Frequency Band 2.4 GHz, Channels 1-13
- Protocols/Profiles UDP, TCP, ICMP, DNS, HTTP(S), DHCP, SMTP, SNTP, OTA
- Security ââ¬â Open, WEP, WPA, WPA2-PSK
- Comms Range > 330m line of sight (û/4 antenna)
- RF Transmit Power +19dBm (11b), +16dBm (11g), +14dBm (11n)
- RF Receive Sensitivity -94dBm (11b/g), -90dBm (11n)
- Operating Temp. -40ðC to +85ðC
- Certifications FCC, CE, IC
- Single wifi IP Adddress and Port (ETH03 has 2 ports) in Server Node
- Higher speed data transfer 38400 baud than USB or ETH03 (9600 Baud). Wifi01 plug in to CM9001 wil have the highest speec as there is no RS485 bus involved.
- Network Date/Time Update every day with Daylight saving time correction.
- Current < 100 mA
- Comfigurator Read/Write, Upgrade Firmware, Upgrade Vocabulary
- Access by Cytech iOS/Android Apps
Wifi01 can be ordered by itself to be plugged in CM9001 or UCM06, or it can be ordered as UCM/Wifi01 (UCM06 + Wifi01)
The Wifi01 package includes
- Wifi01 submodule
- WA02-0004 Antenna with MMCX connector
- 2 x M3 screws and standoffs
- CM9001 firmware 7.173 (Wifi01 plugged in CM9001)
- UCM 7.137 (Wifi01 plugged in UCM06)
- Comfigurator Version 3.13.5 and above to set up Wifi01 in Options > Settings
- RESET - Reset Wifi01 Module
- SOFT - Soft AP Button ( See Instructions below)
- FRST: Factory Reset. (See Intsructions below)
- TXW (Red) - Blinks when data is transmitted to Wifi
- RXW ( Green) - Blinks when data is Received from Wifi
- IP (Green) - Fast Flash when Wifi01 is not in network, Slow Flash when network is joined
- Soft AP (Red) - Flashes when in Soft AP mode, Off when in Normal Station Mode
The Wifi01 Manual can be downloaded from https://www.cytech.biz/wifi01_submodule.html
