Threads: 16
I want to replace a few words in the vocabulary, so I downloaded the voiceproc software but I have no idea what to do. The links to the voiceproc.pdf file don\'t work, so does anyone have a simple guide to just making a few substitutions?
Thanks.
Threads: 16
Thank you, I don\'t know how I missed that! Does it matter that Comfigurator has myma43.bin in the config folder and the myma_IVS.zip file only has myma36.bin?
Threads: 885
Myma43.bin is the result of Voiceproc existing configuration . When you use Voiceproc, it will create a new .bin file (use a different name) that you use to upgrade the Vocab in Comfort
Threads: 16
I\'m sorry, I have weasted several hours on this but I cannot make any sense of the instructions!
I simply want to add the words EnSuite, Rear, Shed, Sliding and Vibration to the Myma list. All of them apart from Back are listed as wav files in the Myma_Highpass.wvd folder, but not in the myma.dat foder.
When I open the myma39.ini in Voiceproc, they are not listed.
Can you explain what exactly I need to do?
Thanks.
Threads: 885
09-14-2020, 02:27 AM
(This post was last modified: 09-17-2020, 05:33 AM by slychiu.)
The latest ivs files are attachedfrom myma43.ini
VocabNo=05
VocustNo=255
VocSysVer=43
VocUserVer=1
VocTextVer=2
LCDVer=3
WavesDir=kate.wvd
CompressedDir=kate.dat
VCD_Quality=mid
VocabularyFileName=kate43.bin
SentencesFileName=sentence36.tab
LCDFileName=lcdkp_v38.cfg
MaxSentenceLength=10
NumOfSysWords=207
SetVol=0.6
TranslationFileName=translat36.tab
NumOfUserWords=141
[color=\"#ff0000\"]UserFileName=resid36.tab[/color]
NumOfTables=5
[Tables]
Table0FileName=newtab0.tab
Table1FileName=newtab1.tab
Table2FileName=newtab2.tab
Table3FileName=newtab3.tab
Table4FileName=number4.tab
[color=\"#ff0000\"][color=\"#ff0000\"]UserFileName=resid36.tab[/color][/color][color=\"#ff0000\"][color=\"#000000\"]resid36.tab is the file that you have to amend to add or change the words
[/color][/color][color=\"#ff0000\"][color=\"#000000\"]Rename the file from myma43.bin so you can create a new bin fole[/color][/color][color=\"#ff0000\"][color=\"#000000\"]
[/color][/color][color=\"#ff0000\"][color=\"#000000\"]Then use Voiceproc to generate the new bin file
[/color][/color][color=\"#ff0000\"][color=\"#000000\"][/color]
[/color]
Threads: 16
I\'ve used the ivs files you sent, and made some progress. I can create a bin file which uploads OK to Comfort but I can\'t get the words to appear in Comfigurator. Also, the options to save user word file and to Save ini file are greyed out in VoiceProc.
Loading the myma43.ini file from above gives these errors:
Opening C:\\Temp\\VoiceProc\\myma43.ini
[General] =
VocabNo = 05
VocustNo = 255
VocSysVer = 43
VocUserVer = 1
VocTextVer = 2
LCDVer = 3
WavesDir = kate.wvd
CompressedDir = kate.dat
VCD_Quality = mid
VocabularyFileName = kate43_custom.bin
SentencesFileName = sentence36.tab
LCDFileName = lcdkp_v38.cfg
MaxSentenceLength = 10
NumOfSysWords = 207
SetVol = 0.6
TranslationFileName = translat36.tab
NumOfUserWords = 141
UserFileName = resid36.tab
NumOfTables = 5
[Tables] =
Table0FileName = newtab0.tab
Table1FileName = newtab1.tab
Table2FileName = newtab2.tab
Table3FileName = newtab3.tab
Table4FileName = number4.tab
WORD_PAGER cannot be found
Error looking up word in C:\\Temp\\VoiceProc\
umber4.tab line# 34 : WORD_PAGER WORD_CODE
WORD_EVENT cannot be found
WORD_LOG cannot be found
umber4.tab line# 47 : WORD_EVENT WORD_LOG
umber4.tab line# 48 : WORD_EVENT WORD_LOG WORD_ERASED
WORD_DELETE cannot be found
umber4.tab line# 59 : WORD_DELETE WORD_MAILBOXES
umber4.tab line# 79 : WORD_PAGER WORD_DIAL WORD_OK
WORD_ANSWERING cannot be found
WORD_MACHINE cannot be found
umber4.tab line# 110 : WORD_ANSWERING WORD_MACHINE WORD_BYPASS
Threads: 885
09-17-2020, 05:38 AM
(This post was last modified: 09-24-2020, 02:11 AM by slychiu.)
You may be working from an old comfiguration
Please use the attached configuration files
The message shows where the error is found
Error looking up word in C:TempVoiceProcnumber4.tab line# 34 : WORD_PAGER
This means that number4.tab file referes to PAGER WORD but the words cannot be foundThis could be due to the old configuration
Threads: 16
OK, I give up on this, it\'s just a mess. That\'s the same file as you already sent me, and the dates on the files go back as far as 1996!
I\'m using Comfigurator 3.13.5.0 with the latest version of the VoiceProc software and all I want to do is replace a few words in the vocabulary. There are three different dat folders which seem to have different selection of words and the documentation is useless.
Threads: 885
Sorry, it is not easy to follow and not easy to explain without spending a lot of time If it is just a few words I suggest you just use what you have
