Low level audio output instead of speaker level for alarm
Just checking, is there any way I can tap off a low level audio output from the PCB? The current audio output for alarms is amplified and ideally I\'d like to tap off an RCA level feed that I can mix with others before piping to a set of ceiling speakers. (Ideally I\'d like to avoid a conversion high level to low level and tap off the main board)Same question from a slave board which happens to be nearer...
Thanks!
If you mean the Siren Output, no, this is a square wave signal and there is no  low levekl audio output
However you can use the AUD01 audio output submodule which plugs ito a UCM/USB or UCM/ETH03  This has a phone jack which you can connect to an amplifier and has a cvolume adjustmentThe output from the AUD01 will be keypad speaker output, ie you will hear the keypad siren sounds and announcements lie a normal speakersee manual attached
.pdf   AUD01man.pdf (Size: 71.03 KB / Downloads: 7)
