Counters mapped to Z-Wave nodes appear to be read-only ?
I have several Aeotec dimmer modules in my Z-Wave network, each of these nodes is mapped to a counter in Comfort.
If I look at the list of counters in Comfigurator, and tick \"Show Status\", I can see the expected values change in real time as I turn lights on/off or dim them from the wall switches.
However whenever I try and write a value to the counter, the counter status briefly changes to the requested value before reverting back to the previous state.It\'s as if the counters are \"read only\".If I try and set counter 31 to a value of 254, while the lights are switched off, I see the following messages on the UCM I/O monitor
> C!1FFE00
< OK
< CT1FFE00
> C?1F
< C?1FFE00
< CT1F0000
If I view the Z-Wave node in the \"Z-Wave mapping\" tab of the Z-Wave UCM, and click \"Switch Device On\", the lights come on.So the ability to communicate via Z-Wave is OK, it seems an issue with the counters?
The Z-Wave device is setup as suchBig Grin
DeviceID: 31
Description: Routing_Slave - Power_Switch_Multilevel
Node Type: BasicListening: Yes
Register Type: Counter
Ch1 Register Number: 31
Ch1 Register Name: Counter031
Using:Comfigurator V3.13.3.0
Comfort II Ultra firmware 7.160
Z-Wave UCM firmware 7.102 Thanks for any help!!
The counters cannot be read only. The zwave device may be preventing changes to it in some way
Can you try using tge Zwave actions to sebd commands instead?
Thanks, using ZWave actions seems to work.
I\'d been using the counter approach for some time, based on the instructions in the UCM Zwave manual, but it stopped working. I have updated Comfigurator, and the firmwares on Comfort and the Z-Wave UCM so perhaps that caused it ?
Anyway, working now, thanks for the prompt help.
Thanks for the confirmation. Counters should also work for Zwave
Can you try using some other counter values besides FE?
