Threads: 6
Are the instructions on this forum the most recent ones for iOS? I could not get the Comfort file to open from Outlook or Gmail, but I did get the native Apple Mail app to give me a \'Copy to Comfort Mobile\" option in the context menu.
I was then able to login, but I could not see any zones, just the dashboard home page. I also get logged out within a few seconds.
What are the recommended steps to follow for current versions of iOS on iPhone (11 Pro) or iPad? Does iTunes need to be involved?
Threads: 885
05-17-2020, 03:10 AM
(This post was last modified: 03-03-2023, 01:52 AM by slychiu.)
In Setup there is an Import Button,
Select the jrlccip file that was attached to the email. apple has changed the way it works with this attachment a few times
Threads: 6
I tried saving the jrlccip file to Files in addition to then clicking the \"Copy to Comfort\" option from the context menu in the Mail app. When I go to Setup->Import in the Comfort app, I see only 2 preinstalled jrlccip files, DevelopmentTesting and Dollhouse_with_dimmer and there is no way to navigate to change folder to locate the file I downloaded.
Threads: 885
05-19-2020, 02:50 AM
(This post was last modified: 03-03-2023, 01:54 AM by slychiu.)
I tested this again.
In the email, tap the jrlccip attachment
In the list of apps, select More... select Copy to Comfort iPhone
The Comfort app appears with box
Load Config
Please select Comfort System
Dismiss Default
Select Default
A box appears
Load Config Config Data Loaded - Please sign in
Dismiss The box disappears and the Comfort setup/login screen is seen
You should be able to go to Setup or Login
If you log in and do not see any zones or Control menu then the configration file may be corrupted. go to Comfigurator, preferable rename the cclx file and resend the conversion file.
Threads: 5
Tried both methods today and neither work. all I get in the control area is Group_0 with nothing in it.
Threads: 885
Did you do the conversion and send the jrlccip file by email? do not use gmial to do this as it deletes the content of the attachment. use another email client The file size should be several KB
Threads: 5
Yes, followed the instruction above, method 1. I used an microsoft outlook email address. It all seems to work but there is no data in the app after the file has loaded. Tried it several times, including changing the file name.
Threads: 885
Can you send the cclx file to support@cytech.biz?
