How to determine CCTV compatibility?
I\'m leaning towards purchasing the following Hikvision cameras and was wondering how I could confirm if they will work with the Comfort app?
https://www.use-ip.co.uk/hikvision-ds-2cd2385g1-i.html
https://www.use-ip.co.uk/hikvision-ds-2c...wd-is.html
No, the Comfort app will not work with CCTVs by itself. You have to use the manufacturers own app
If you are using Android, their is an app called IP Cam, this can be used inside the comfort app for CCTV however it becomes pointless as the app itself has a widget which shows the cameras set at your prefernece for interval. I believe the app works with Hikvision but you would need to check before downloading or buying.
