Threads: 888
03-28-2020, 03:00 AM
(This post was last modified: 10-24-2020, 02:57 AM by slychiu.)
Known Bugs (Remaining)
- Responses with AND and OR Conditions after Read from Comfort are decoded incorrectly. If you have such conditional actions in any Response, do not Read from Comfort except for checking only. This bug is from long ago
- [color=\"#ff0000\"]Action Set Virtual Input does not select Virtual Input, selects physical input instead[/color]
- [color=\"#ff0000\"]UCM/Cus2 Cbus to Comfort Output status is wrong when map to lighting group address. Output -1 status is shown instead of output number status[/color]
- [color=\"#ff0000\"]Set login partition action has error[/color]
- [color=\"#ff0000\"]Security Node Responses and siren outputs programmed in old cclx files are not in Partition events when opened in 3.13.5[/color]
Bugs Fixed- Fixed Bug IRIO analog output registers not shown as referenced
- Fixed Bug IRIO with modules. eg ISM01. Open new file and scan for modules. IRIO is detected, click on IRIO, ISM01 is seen but we cannot see any IO under ISM01. We must select None or other submodules then select ISM01 then the I/Os under ISM01 can be seen
- Fixed Bug \"Subtract sensor from last action\" was wrong
Changes- Added Occupancy status on the status bar, to show if the premises is occupied. See http://www.comfortforums.com/forum20/5158.html
- Occupancy commands dR or d? Occupancy Active/Inactive
- Action 73, 32 Get Occupancy Status (73,32)
- added Support for Wifi submodule (coming)
- Added Timers status to register monitor.sort by name and number. However the register values canbot be changed. See http://www.comfortforums.com/forum20/5149.html
- IRIO modules if IRIO was present but now is not found, dont give error messagfe to avoid several error messages due to Submodule not correct
Threads: 888
Comfigurator 3.13.2 (Beta)
New Features and Improvements- Register Monitor allows change of register values
- Register Monitor includes Timer values
- In Responses, when any Comfort Register is used, the Register number is appended, eg Get Counter Dim (7) The counter named Dim shows the Counter number (7)
- Events > Partition Events now has Security Off Response, Away Mode Response, Night Mode Response, Day Mode Response, Siren Outputs. These have been moved from the Misc Events Screen for better organisation, and allows more partitions to be added later
- New UCM/wifi module support has been added.
- UCM/Modbus will allow wifi interface and Virtual Input mapping for modbus not connected. This requires a new UCM/Modbus firmware yet to be released
Threads: 888
06-17-2020, 06:44 AM
(This post was last modified: 07-27-2020, 04:17 AM by slychiu.)
Comfigurator 3.13.3
[color=\"#ff0000\"] myma.cfg was missing from the installation. Starting a default template will have an exception.If you have download Comfigurator 3.13.3 on or before 18 June 2020 and have this problem, please download Comfigurator 3.13.3 again and reinstall
[/color]
Known Bugs
- Sunset Response does not work even though the Night Flag is turned on at sunset
- Occupancy Timer in minutes is not written to Comfort
Bugs Fixed from 3.13.2- Initialise Counter - Counter value is always = counter number eg Counter 7 =7
- Ucm/LOGIC add UCM gets exception from 22/3/2019
- FS35 read user codes gets exception
- FS35 Partition events not correct -
- users engineer code is repeated, engineer code should not have authorisation
- In Existing cclx file created before 3.13.2, if UCM/ modbus is selected, an exception appears, but create new file and add modbus is OK
Changes and New Features- Partition Events have been moved to Security Category
- UCM/Modbus allow map virtual Input to modbus not responding. This requires a new UCM/Modbus firmware to be released
Threads: 888
Bug in 3.13.3
This will be fixed in the next version
Threads: 888
07-16-2020, 12:08 PM
(This post was last modified: 08-05-2020, 08:49 AM by slychiu.)
Comfigurator 3.13.4
Fixed Bug - Sunset Responses does not work
Known Bugs- [color=\"#ff0000\"]Alarms > Partition Events> Responses (ie Security Off, Away, Night, Day, Siren Output )which have been programmed here become blank after saving the file. Wen the file is opened again, the Partition Responses are blank.[/color]
Please download from https://www.cytech.biz/product_details.php?item_id=206
Threads: 888
08-05-2020, 08:51 AM
(This post was last modified: 08-05-2020, 09:17 AM by slychiu.)
Bug found in 3.13.4
[color=\"#ff0000\"]
[/color][color=\"#ff0000\"]
[/color][color=\"#ff0000\"] [/color][color=\"#ff0000\"] [/color][color=\"#aa0000\"]Alarms > Partition Events> Responses (ie Security Off, Away, Night, Day, Siren Output )which have been programmed here become blank after saving the file. Wen the file is opened again,
[/color][color=\"#aa0000\"]Plrease do NOT upgrade from 3.13.1 if you have bot done so[/color][color=\"#aa0000\"]
[/color][color=\"#aa0000\"]If you have upgraded to 3.13.3 or 3.13.4, downgrading will cause errors in the responses due to the Register Numbers which have been added to the names after 3.13.1
[/color][color=\"#aa0000\"] [/color][color=\"#ff0000\"] [/color]
Threads: 888
To work around this problem when you have upgraded to 3.13.3 or 3.13.4;
If you have already done a fulll write to Comfort after upgrading to 3.13.2 or higher, The Away, Night Day, Security Off responses may ot be empty in Comfort.
Assign the Responses again for the partition mode responses, and write seletive or Full to Comfort.
Once you save the file, these Partition Events will be lost.
If you have to make changes anywhere in the configuration and need to write to Comfort again, do a Selectve Write and Exclude the Partition Events, so you do not write blank partitions events to Coomfort
Threads: 31
If you have down graded to 3.12 after finding issues using the latest version and still have problems, what would be the advice to take then as I guess that you are saying a down grade will still have the latent problems in partitionioned Zones?
As this is what I had done and have problems in the partioned zone (my workaround was to alter the zones that were used to speare zones and re-create.
Threads: 888
3.13.2 and 3.13.4 has the same problem as 3.13.4 ie Partition events are ostso you might as well upgrade to 3.13.4 and use the workaround that I mentioned in my last post
Threads: 206
This is turning into a bit of a nightmare !
It now been MONTHS since this bug was reported and I\'m getting complaints from customers that we have been to provide service etc that now have problems that they DID NOT HAVE BEFORE WE VISITED !
WHEN IS THE FIX AVAILABLE
WHEN CAN WE SENSIBLY DOWN LOAD 3.13.5 and KNOW THAT IS RELIABLE !
Not so worried about the partitions BUT things like the daylight are crucial !
Please advise soonest
