02-17-2020, 11:34 AM
Odd problem.
Changed 10yr old Cequra1 box about 18 months ago for a Cequra Super plus. All seemed to work but on routine check after a few months I found the strobe was only working intermittently - flash a few times then give up or not at all. I thought it was a board fault and swapped to a new identical unit I keep as a spare. This appeared to work initially but soon developed same problem. Tried a third - same story. Never a problem with the siren circuit. Checked wiring to box is good.
Bench tested with 12vdc and the strobes worked but did appear a worryingly flakey at times. Cequra customer service say that there are no known strobe problems with this unit.
Checked Comfort outputs (PC01-070A ULT 7.x)
RTN -- tamper
Hold off+ -- SRN+
Hold off neg -- COM
Siren -- SRN-
Strobe -- STB-
With 1k resistors fitted and connected to box;
SRN+>STR- 1.2v off, 13.1v on
STR->COM 12.5v off, 0.6v on
SRN+>COM 13.7v
On open circuit with resistors, the values are about the same.
This looks correct to me. Comfort is pulling the STB- output to <3v when on.
Can\'t fathom out what is the problem here. 3 bell boxes with dodgy boards ? Excessive current requirement ? Anyone else come across this? Should I ditch the boxes and try a newer LED unit - I understand these are 10yr old design? Thoughts appreciated.
RTN -- tamper
Hold off+ -- SRN+
Hold off neg -- COM
Siren -- SRN-
Strobe -- STB-
SRN+>COM 13.7v
hock:
