Threads: 31
With the OPO1 if the board goes you would just replace the board, if this goes you have to replace the board or is that a resetable fuse set into it, also what what is the voltage max capacity.
Threads: 865
If this fails you also replace the submodule just line OP03 and OP01
It is less likely to fail than OP03 or OP01 because the relays have 5000V isolation/breakdown volatge.
In OP01 and OP03 the outputs are open collector transistor outputs and are more easily damaged
