Any attempt to write resets Comfort
After many many years, I finally got round to doing the UCM cable upgrade method and performed a system wide upgrade of Comfort from v6.0x to the latest and all the UCMs. That appears to have been successful.
I then noticed today some lights were on and some groups not updating from CBUS, although I can still control CBUS OK where I have the CBUS switch activate a Comfort output, so not totally disconnected.
Anyway, I thought I\'d just go and re-write the entire current Comfort configuration back to Comfort and have a clean config. The problem I have is that any attempt to write the config to Comfort just resets Comfort, the write bar stuck at 0%.
I\'m using Comfigurator 3.12.15 via one UCM, and I\'ve also tried Comfigurator 3.6.8 on a different UCM. Attempting on both exhibits the same issue. I also yanked the power to the board and the battery, and tried again, same issue.
So, right now I have a \'sick\' system that isn\'t totally response, and no apparent way to re-write the config back. Each time I make a config change I create a new file, and have copies going all the way back to 2004. My latest config was created a week ago and worked perfectly well before the firmware upgrade.
Any ideas on how I can debug this, or reset Comfort to be able to write the config back?
Thanks!
I have a feeling that an input from 17 onwards isn\'t being read neither, they\'ll be inputs from a daughterboard?
Update, even input 1 which is an exit route is not working, so I cannot arm the alarm at all!
I\'ve now reflashed the Comfort firmware with the same revision, no change, still resets on any attempt to perform a full config write.
Can you do a read from comfort and save the file then send to support @cytech  BizCan you do a scan for modules
Yes, I can scan for modules, that seems to work as it did before. Comfort to CBUS is still working, but Comfort input detection doesn\'t fully appear to work correctly across the board.
I\'ll send the config file now. This config file was working before the firmware update.
I also just tried loading Comfigurator with NO config, performed a selective READ on just the zones/inputs, then attempted a selective WRITE on just zone/inputs. Counter stopped at 2% and Comfort reset itself, so this doesn\'t appear to be my config that\'s at fault?
Some updates. I believe inputs 1 - 16 are working OK, inputs 17 upwards are not. 17 is a final exit door, and 18 is an InstantDayNightAway door.
So something has gone wrong with the firmware update that now means the expansion module is not being detected as well as the inability to write a config.
Do you have a SEP  or LEM03 ?
Check the upgrade to 7.X or tick box for LEM.
Have you tried changing the U4 chip ! There is usually a spar in the older UCM slots
I\'ve managed to get things working using this specific sequence
-Downgrade Comfort to 7.032
-Power cycle Comfort
-Re-write the exact same config back to Comfort
This works.
I then try every single version of the firmware posted from 7.032 to 7.160, all 18 of them.
The last version to work is 7.099, and all versions after that fails to work. I have an early C2 board which has the upgrade firmware on a small daughterboard if that makes a difference.
So, I think I\'ve been quite thorough, and that ask of Cytech is, what changed in 7.099 and can we put that fix into a new version so I can upgrade to the latest.
Thanks that is very thorough, we will check the changes after 7.099However there are many systems which were upgraded past 7.100 so it is a mystery  at the moment. Ppwerhaps it has to do with the cclx file
I don\'t think it\'s the config file. On the latest firmware, if I load Comfigurator with no config at all, do a read of the config from Comfort, and then attempt to write that back, it fails and resets Comfort.
