Compatibility of CM9000/CM9001 Modules
CM9001 Modules Can be Used for CM9000?
  • LEM02B: No, cannot be plugged in to CM9000
  • LEM01/02/03B:  Yes but have no EOL shunts, MUST connect EOL Resistors
  • SEP01C/SEM01C:  Yes
  • DSI01:  No, CM9000 use RGR05
  • OP03:  No, cannot be plugged in to CM9000. Use OP01 for CM9000
  • TT01-0022 Power Supply:  No, CM9000 use T-230V Transformer
  • CM9001 CPU side:  Can be used with CM9000 DSP
  • CM9001 DSP Side:  Can be Used for CM9000 CPU  (needs TT01-0022 DC power supply)
CM9000 Modules Can be Used for CM9001 or SEM01C?
  • LEM01/02/03-M2:  Yes, the EOL shunts must be set to Double EOL and 2 EOL resistors must be connected to each zone.  It is recommended that  the old LEMs be changed to thenew LEM01B, LEM02B, LEM03B
  • SEP01/SEM01-M2:  Yes
  • RGR05:  No, CM9001 use DSI01
  • OP01: No, cannot be plugged into CM9001. Use OP03 for CM9001
  • T-230V:  No, CM9001 use TT01-0021
  • CM9000:  CPU side Can be used with CM9001 DSP
  • CM9000:  DSP Side Can be Used for CM9001 CPU (needs T230V AC transformer)
  • KP04, KP05, KP03 (non partitioned systems)
The following modules can be used on CM9000 and CM9001
  • UCMs
  • Keypads KP03, KP04A, KP05A
  • Door stations
  • HIO
  • IRIO
  • RIO
  • TSM
  • CSM03
  • TWS
  • IR01/02/03
