06-11-2019, 09:20 AM
while updating the system from 7.140 to 7.142 I got a time out message and now nothing works, cant even login.
Firmware Upgrading System failure
06-11-2019, 12:18 PM
When you have a failure during upgrade there is a message \"Continue from last addrress? Pres yes and the upgrade will continue
If it does not for any reason repeat the upgrade. It should work unless there is an issue with the UCM Also you can do the firmware upgrade using the UCM Firmware Upgrading cable
In the forum \"Firmware Upgrading Problems\" http://www.comfortforums.com/forum111/2967.html it advises to immediately do the upgrade again if there is a failure
The other way using the UCM Firmware upgrading cable is described here http://www.comfortforums.com/forum4/1216.html This should work for a system which has corrupted firmware upgrade
06-11-2019, 12:27 PM
(This post was last modified: 06-11-2019, 12:29 PM by raygregg114.)
tried upgrade twice but after second failure nothing workspety saying UCM Failurenow not even signin codes work
06-11-2019, 12:40 PM
Now giving me a message when i try to upgrade using cable
Failed to connect to UCM - please check the UCM connection settings
06-11-2019, 12:52 PM
Also i dont have a USB connection. Modules are ethernet and GSM
06-11-2019, 12:54 PM
Use the UCM/ETH03 to upgrade the firmnware by the UCM Firmware Upgrading methodDo NOT sign in. Transfer > Upgrade firmware by UCM Upgrading Cable, follow the instructions in the forum
06-11-2019, 12:56 PM
https://www.cytech.biz/upgrades.html
web link not available, where do i download firmware file?
06-11-2019, 01:30 PM
OK all cables connected and usb connected to PC. Still getting same message
Failed to connect to UCM - Check UCM settings
06-11-2019, 01:31 PM
Right click on Controller in Modules Tab and select Download UpgradeThis will automaticallly download the current firmware into a local folder for you to select
for direct download link go to https://www.cytech.biz/comfort_ultra_firmware.html |
| 1 Guest(s) |
