Threads: 98
I\'m looking to add the UCM/Pi, and curious if it will be able to send out commands to other smart devices, such as sending an on/off command to an Alexa enabled mains switch?
If so, that would mean my CBUS switches can then control Alexa enabled mains modules, which would be amazing.
Threads: 21
Hi Palmlodge.
If you\'re interested in the UCM/Pi and are prepared to join the beta programme (as wexfordman has), please drop me a note on matt.brain@alphawerk.co.uk and we can go from there.
Thanks,
Matt
Threads: 7
I have Cbus and Comfort all set up at home running on a raspberry pi using Openhab along with Alexa and various other devices. As long as you have a Raspberry pi running cgate and Openhab you can communicate to Comfort via the Eht03/UCM. I\'ve only just got my Comfort system up and running but already I have it communicating with Openhab via MQTT, the response rate is super fast even when not on the same network.
Please to help if needed
Cheers
Matt
Threads: 21
Good to hear Matt.
We have OpenHab and HomeAssistant support running including automatic discovery of objects over MQTT. All this is done on a UCM/Pi which is directly connected and powered by the Comfort system, benefits from a higher baud rate than a standard UCM and has a hardware watchdog to monitor its health.
Happy to show you round if you wish to discuss further,
Thanks,
Matt
Threads: 7
Cheers Matt,
I\'m just getting my head around comfort at the moment, i luckerly moved into a house 3 years ago that had CBus and Comfort already installed but the previous owner didn\'t know how to use them and they were redundant for around 10 years. So i\'ve had Cbus running on Openhab for a good while, the only time it has crashed is when i\'ve been \'playing\' with it. My kids think its normal now and use it regularly via Alexa etc, I also have a few Hifiberry\'s that are connected to cbus via Openhab so the kids can play music in their rooms using the cbus saturn lights that has been programmed to start a playlist using Openhab and Volumio.
My point is is that i just purchased a Eth03/UCM so i wont be buying anything anytime soon as the wife will go nuts.
Have you created a binding for Openhab?
Cheers
Matt
Threads: 21
Not a binding as such, but as OpenHab supports HomeAssistant discovery over MQTT, I just created a flow which used it.
Thanks,
Matt
Threads: 7
Ahhh yes node red, i haven\'t got my head around that yet...can you publish commands to comfort such as arming the alarm or only subscribe to in coming messages
cheers
