Unable to connect to UCM eth02
After several years of the system running well I decided to add some more functions and installed a ucm z-wave. I was able to connect to everything using configurator.
I then did the firmware upgrades and I thought all was fine. I went back to the system a couple of hours later and it appears that ucm eth02 is not connecting to the network. If I run the dsmanager on the network nothing Is found but if I plug the module directly to my laptop I can see the UCM and set the IP or dhcp.
When plugged into the lan the device does not show up in the list of connected devices on my router list.
Can anyone help me trouble shoot this?
Check if you have another network adaptor in the systemdisconnect all other network adaptors
Hi do you mean disconnect everything else from the router? I don\'t have any other network adapters in comfort.
Also what firmware version should be installed, want to make sure I have the correct one.
Not network adaptors in ComfortOther network adaptors on the computersee http://www.comfortforums.com/forum113/3823.html which is for ETH03 but also applies to ETH02
Anyway if it can work by directconnection to the PC use DS Manager to set the IP address of ETH02, then connect ETH02 to the network and enter the IP addtess and port
ETH02 is not produced anymore. I auggest that you get a ETH03 to replace the ETH-02 to avoid future problems
Thanks I will try when I get back. I want to get thr pi module when available. Mot sure if this will negate the need for an eth03
Thanks this worked and I can connect again
