Cytech is pleased to introduce the KNX/Logic Processor.
The KNX Logic Processor is an Automation Controller with a KNX Interface which can work with other Cytech interfaces including CBUS, Z-Wave, GSM, Modbus, Velbus, IRIO, HIO Hotel I/O. KNX/Logic is applicable to an automation system which does not require the Comfort Intruder Alarm, but has the same capability of Comfort for Responses, Time Programs, Timers, Counters, Flags, and Sensors. It does not have the Voice recording/playback, voice menu, dial out, and telephone interface of Comfort and does not have any inputs and outputs.
Key Features
Key Features
- 2 way KNX Interface able to send telegrams to KNX and receive from KNX
- Scheduling with 32 Time Programs.
- KNX buttons can be mapped to Comfort Counters, Flags and sensors, allowing control of non-KNX appliances like air-conditioners and other 3rd party automation systems
- Synchronise KNX/Logic real time clock to KNX devices. KNX/Logic has automatic Daylight saving adjustments and Sunrise/Sunset times based on locations. The optional UCM/ETH03 module is synchronised to Internet Time Servers.
- Read Temperature and other sensors on the KNX bus or supply temperature readings or setpoints to KNX from Cytech modules like MSM01 Multisensor Module
- Functions as a Central Processor/controller for an KNX network which is able to coordinate the functions of all the subsystems including security, lighting, HVAC, and others. KNX/Logic is able to take action based on conditional logic, for example, when the time is between 7 PM and 7 AM, on selected days of week etc
- Control KNX devices by Cytech mobile apps (iOS and Android)
- Interfaces to other systems eg C-bus, Modbus, etc by Cytechs UCM interface modules
- UCM size 108 x 88 mm
- Direct connection to KNX bus
- Power Supply 12V to 15V 1A wallmount universal adaptor 90V to 240VAC with UK, EU or US plug. The KNX Bus is isoolated from KNX/Logic voltages.
- Control Menu ââ¬â 8 Control Groups, each with 10 control keys, each control key has 10 Action keys.
- 512 Responses for custom programming
- 255 Counters can be mapped to KNX, Cbus, Zwave, IRIO, HIO etc
- 255 Flags can be mapped to KNX, Cbus, Zwave, IRIO, HIO etc
- 32 Sensor Registers can be mapped to KNX, Cbus, Zwave, TSM etc
- 32 Time Programs or Schedules
- Sunrise/Sunset times with automatic daylight saving time adjustments
- 64 Timers for programmed delays 1 to 65534 seconds.
- Current Consumption 30 mA @12V
- Connected to KNX Bus via bus cable (2 wires).
- KNX Physical addresses can be assigned to KNX/Logic, Area 0 to 15, Line 0 to 15, Physical Address 1 to 200
- KNX to Comfort allows 256 Group addresses to be mapped to Comfort.
