Real input zone gone "virtual"
Zone input 17 has got the virtual input checked, I have made some changes to the config recently to shunt this zone via an RS485 message but now the zone doesn\'t detect anymore.
.cclx   96 active.cclx (Size: 272.39 KB / Downloads: 2)
I have edited the cclx file to remove the Virtual Property from zone 17It appears there is a bug in Comfiguratorwhen you map a zone to Bypass Input in Universal UCM, the zone becomes Virtual, which should not be soAnyway do not change the mapping of Bypass zone in Universal UCM otherwise it will cause another zone to become virtual
.zip   96 active1.zip (Size: 25.24 KB / Downloads: 2)
Hi Slychiu, thanks for the fast response. I shall heed your warning.Thanks.
PH did you used to work for Sch !
If you mean South Cleveland then yes!
Nope Schneider !
6 Guest(s)
