I\'m having problems with getting feedback from the UCM_KNX2.
KNX -> Comfort...
0/4/7 (1-Bit) \'Blind up/down\' mapped to Counter031
Counter031 response...[indent]If LastUcmCounter = 0 Then[/indent][indent]Do BlindUp[/indent][indent]Else[/indent][indent]Do BlindDn[/indent][indent]End If[/indent] Counters->KNX (1-Bit)...
Counter031 mapped to 0/4/8 (1-Bit) \'Blind up/down status\'
In this instance (If I understand the UCM manual correctly) GA 0/4/7 should alter the value of counter 031, which should alter the state of GA 0/4/8.
In reality, when Group Address 0/4/7 is set to \'ON\' the blinds come down, and when Group Address 0/4/7 is set to \'OFF\' the blind go up and I can see the counter value change in Comfigurator (Comfort Registers) so this all seems to be correct.
However, the status value DOES NOT change in the status columns of the UCM and I don\'t see any telegrams to Group Address 0/4/8 in the group monitor on ETS, or any other indication that I\'m receiving feedback from the UCM_KNX2.
What am I doing wrong?
KNX -> Comfort...
